Old 12-12-2013, 02:57 PM   #80 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I have talked to hundreds of pickup guys and the trend is very clear:
Bigger diameter wheels/tire = worse MPG.
The reason is straightforward. Unless you run very long legs at the same road speed, you have to accelerate. Not only do you have to accelerate the vehicle, you must first accelerate the wheels/tires before they will accelerate the vehicle.
The polar moment of inertia goes up with the square of the diameter, so if you go from 13 inch wheels to 16 inch wheels the polar moment of inertia increases by 33%. The wheel/tire assemblies act like flywheels.
Look at the high-MPG cars available. Small diameter tires. 13 or 14 inch. No 18 inch wheels on the vehicles with high MPG.
Stay with the factory-sized rubber. They do know what they are doing.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
t vago (12-12-2013)
