If you can build that HHO generator then you should really try building something proven to work like an air dam or any one of the other 70 or so things proven to work.
For some reason people tend to gravitate toward mods that don't work like gas tank pills, hho or some over elaborate combustion process modification that is so complicated no one can explain how it works.
. . . the internet hacks can't get it to work, doesn't mean it doesn't. Add to that the grossly inflated claims the scammers attribute to the device and all of a sudden, it's stuck in the unicorn corral.
But, the science for HHO is there, though not in the simpleton assessments of the typical internet discussion.
And the gains to the average person are not in line with the costs involved. It's probably better to zip tie pie tins on your wheels.
