The answer is the Government must be wrong, as the percentage increases are based on the results of hundreds of treatments. With a measured COF by a Tokyo bearing company of .0008 - that's damn near zero.
The US Army didn't believe me either, which is why I laid down $35K for testing and was awarded the Mil Spec, and everything else is just oil.
If you screw people on ebay, negative feedback will show up - especially when charging hundreds for MPG enhancement kits, and then look at my feedback. 20% has been the lowest increase in MPG, so consider the treatment unique.
Originally Posted by ChazInMT
I've read through all this and common sense would step in to ask,
What percentage of power generated by the engine is lost to friction?
So I find this. FuelEconomy.Gov
Now it looks to me like the friction loss is 3%, you can't claim your product eliminates friction, so even if you cut it in half, you only reduce engine loss by 1.5%.
How does this yield a 10% or better increase in MPG?
You understand this right? 3% of engine loss is due to friction, how does eliminating this yield a dyno test result that's 20% more horsepower?
A bunch of stories about how much better a gun shoots or how happy people are is not considered evidence as to the effectiveness of a product. Show us independent testing result numbers, cousin Bob winning his first race does not count.
And for the sake of Pete, do NOT go on some pseudo-science technobabble diatribe here, you will look pathetic if you try.
Plain English and simple terms following a logical progression of how it is that you can make a 3% loss result in a 20% gain would be really appreciated.
