Originally Posted by DiamondLube
What happens when the cylinder and compression ring gets Coated with atom sized balls of spherical Diamond? How many changes "if any" do you think will occur?
That's precisely what I'm asking. If you have oil slipping past rings how do you know if this stuff won't slip by even easier?
Edit: I'd actually consider trying this stuff on some systems like wheel bearings and power steering. Maybe tranny. How much would you inject into a wheel bearing?
