Old 12-30-2013, 03:59 PM   #82 (permalink)
jackbauer
jackbauer's Avatar
Folks , sorry for a lack of updates in the thread been busy with work etc on the run up to Christmas. Thought I had hit a roadblock recently (visions of the Vanishing Point bulldozers!) when I couldn't fit a 2.8 ratio diff as planned due to different flange sizes on the half shafts and prop shaft. Thankfully getting to grips with it so just means swapping the half shafts and a bit of custom driveshaft work.
@hankjay All my batteries are lithium iron phosphate. The cells in the E36 are headway cylindricals that I really could not recommend due to performance and inconsistencies but they got my feet wet so to speak. Cells in the land yacht are 180Ah CA series from CALB.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
thingstodo (04-27-2014)
