Old 12-19-2013, 01:01 AM   #81 (permalink)
Why the change of batteries
Hi Jack
A bit late, but I have been pondering this question for a while. Why did you move away from the Lithium battery banks, was it eas of use or are the later Lifepo4 (are the ones you used4s) better, cheaper.
There is a lot of noise on the net about different types of batteries and claims, but I have not been able to find a satisfactory answer.
Hank, lives downunder in 43 degrees.
Old 12-30-2013, 03:59 PM   #82 (permalink)
jackbauer's Avatar
Folks , sorry for a lack of updates in the thread been busy with work etc on the run up to Christmas. Thought I had hit a roadblock recently (visions of the Vanishing Point bulldozers!) when I couldn't fit a 2.8 ratio diff as planned due to different flange sizes on the half shafts and prop shaft. Thankfully getting to grips with it so just means swapping the half shafts and a bit of custom driveshaft work.
@hankjay All my batteries are lithium iron phosphate. The cells in the E36 are headway cylindricals that I really could not recommend due to performance and inconsistencies but they got my feet wet so to speak. Cells in the land yacht are 180Ah CA series from CALB.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
thingstodo (04-27-2014)
Old 01-21-2014, 04:23 PM   #83 (permalink)
American Viking's Avatar
Dad's Jetta - '05 Volkswagen Jetta 2.5l package one
90 day: 23.23 mpg (US)
Black Cherry - '01 Honda VFR800fi
Last 3: 39.39 mpg (US)
Originally Posted by jackbauer View Post
Firstly Merry Christmas to all Secondly I'd like to introduce the new project that i have christened the land yacht! Donor vehicle is a 2001 BMW 520I E39 5 series. Equipped with a 6 cylinder 2.2L petrol engine that has a few minor problems This is going to be replaced with a 13" rebuilt forklift motor , 1200amp controller , 15kw 3 phase charger and a pack of 60 CALB 180Ah grey cells. Let's see what happens ........
I just found this as I explore the forum.
I'm working on doing something similar with my wife's 2002 Lincoln LS.
Its a fine handling car, but it is a gas pig.
I have the factory 5 speed transmission on the shelf so I won't be wasting time with the crap-tastic factory automatic transmission when I convert it.
Old 01-21-2014, 04:40 PM   #84 (permalink)
jackbauer's Avatar
Driveshaft now in. Just waiting on the cells. Supposed to be delivered today but of course didn't arrive. Typical couriers!
www.evbmw.com
Old 01-21-2014, 09:07 PM   #85 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
great job, another piece of the puzzle solved.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 01-21-2014, 10:34 PM   #86 (permalink)
The 5 series uses the exact same getrag 5 speed gearbox as I'm running in the 3 series which has just passed 20k ev miles without a clutch and an 11" motor. Two things help here : I would only do about 20% of the shifts in an ev as i would do in an ice and secondly the getrag has very good synchros.
What model Getrag are you using? I'm asking because the Lincoln LS uses a Getrag that is also used in some 3-5 series BMW's, so I might be working with the same transmission.
Old 01-22-2014, 01:12 PM   #87 (permalink)
Sorry for the double posting of the question. I'm having some issue with refreshing the forum posts on this computer.
My laptop is stuck at my house, which with yesterday's snowstorm and traffic issues, I'm not able to get to yet..
Old 02-06-2014, 02:48 PM   #88 (permalink)
jackbauer's Avatar
Latest updates. Motor cooling fan and main battery box and CA180FI cells installed :
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
deejaaa (02-06-2014), thingstodo (04-28-2014)
Old 02-06-2014, 10:48 PM   #89 (permalink)
Not banned yet
deejaaa's Avatar
your information and knowledge is amazing.
Old 02-10-2014, 03:25 PM   #90 (permalink)
jackbauer's Avatar
Land yacht rolled on the full pack for the first time yesterday!
www.evbmw.com
