Old 12-30-2013, 05:44 PM   #2 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
You can rejet the carb to make it run leaner and then advance the ignition timing. I use to buy main jets from a honda motorcycle shop, probably get them on line or ebay. The old CvCC heads could be milled quite a bit. You might want to research main jet sizing and what it has now. You can jet it really lean and put a manual choke on it to adjust the F/A ratio on the fly. Lean burn is about 22:1, stoke 14.7:1. We use to open up the spark plug gap to run leaner without sputtering, up to a point any way.
- Tony
