Old 01-01-2014, 02:27 AM   #41 (permalink)
RustyLugNut
How certain are you?
I am fairly certain no one has gotten it to work.
Why would I waste time building an HHO machine, that is only proven to deliver no results and inconsistent and inconclusive results at best, then always have to tinker with it, adding water or doing what ever you do to make them go.
Then if you do get it to work the oil company has you killed.
Why would I bother with all of that mess when I can build an air dam once, in a day, for about $20, using low value scraps for most of it, never have to mess with it unless the lawn edging gets torn off and gain almost a full MPG?
Last week I was in Maine, the high temperature most days was well below freezing.
In that situation the air dam is not effected.
How does the water filled HHO machine do?
I am very certain HHO works when applied correctly. Many on these forums are certain it doesn't work in any way shape or form.
The proper electrolyte concentrations do not freeze until well below freezing. And, good designs are unaffected by freezing electrolytes.
