Old 01-01-2014, 04:24 PM   #28 (permalink)
gk_ghig14
Eye catcher - '14 Ford Mustang GT
90 day: 17.39 mpg (US)
As far as gear ratio, I have 3.15 and the next tallest is 2.73 from a v6 mustang but gear changes are $500+ easy cause of labor
Tires, after hanging out with a buddy last night, found out technically I can go taller(as in I have wheel well space) but it may be tricky to find the tires. But I may look into it
Also dropped about 10 pounds off the front of the car(strut tower brace removed, sound tube removed, engine cover removed). Then I'll be dropping about 35 pounds off the rear when I take off the mufflers and install deletes
