Old 01-02-2014, 01:10 PM   #27 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I did a pretty good job. I posted this earlier on this thread:
http://ecomodder.com/forum/showthrea...d-19954-7.html
I did pretty good this year--far better than what I'd hoped.
2012 Totals:
Total Fills = 11
Total Miles = 14,637.9 miles
Total Fuel Used = 384.759 gallons
Average Mileage = 38.04 mpg
Best Tank = 1,465.2 miles on 35 gallons (47.01 mpg)
Fuel Cost per Mile = 8.55 cents/mile
2013 Goals:
Total Fills <= 10
Average Mileage >= 41 mpg
Best Tank >= 50 mpg
On a personal note, like most people I have the opposite problem as Pale. Duing 2012 I lost 85 lbs. I'd like to do at least that again in 2013 to put me closer to the "healtly" BMI range.
2013 Totals:
Total Fills = 8
Total Miles = 13,409.4 miles
Total Fuel Used = 283.4 gallons
Average Mileage = 47.3 mpg
Best Tank = 2,009.6 miles on 35 gallons (57.42 mpg)
Fuel Cost per Mile = 6.57 cents/mile
Also, on the weight loss front I made quite a bit of progress. I didn't drop another 85 lbs, but I did drop another 70 lbs in 2013 (170 lbs total). Related to the weight loss goals, I achieved several milestones in running and cycling. I didn't really set goals for myself at the beginning of 2013 per se, but kind of set some out there towards the end of the year. I wanted to run a half marathon distance without stopping, which I did. I wanted to run at least 100 5k's, and completed 110. Total distances for 2013 were 387.5 mi running, and 636.1 mi cycling--1,023.6 mi total, which met my goal of >1,000 mi.
For 2014 I intend to focus more on the fitness probably than the truck, but here go goals for 2014:
1) Loose the last 30 pounds to get down under 200 lbs.
2) Get to 15% body fat (at 23% right now).
3) Run a marathon
4) Get 1 year average mileage over 50 mpg.
5) Get at least one tank better than last year's best.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following 3 Users Say Thank You to Diesel_Dave For This Useful Post:
ecoTex (01-03-2014), euromodder (01-21-2014), user removed (01-02-2014)
