Old 01-03-2014, 08:38 PM   #10 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
9006
9012:
Application notes This new Philips bulb is physically, electrically, optically, and legally compatible with all previous 9012 (HIR2) bulbs, so it can be used for all the same design-specification, replacement, and upgrade applications. It can replace the 9006 (HB4) for special-service use; such a retrofit requires minor modification to the bulb base as described here Like all previous HIR2 bulbs, it does not have a blacked-out tip, which means it should not be used in road going headlamp or fog lamp designs that don't have a bulb shield completely covering at least the top half of the front of the bulb — a ring-style bulb shield that leaves the front of the bulb exposed to the lens is usually not sufficient.
http://store.candlepower.com/ph3rdge90h.html
Goes back to the basic concept. A headlamp is designed for a specific bulb. When you alter the bulb, you will alter the light. they make a point of the black out tip. And I cant tell if the 9012 is a little longer, but by the link, it seems the only issue is the tip/
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
