Got a high of 27.66mpg on the return trip between Biloxi and College Station. Not bad fer towing a loaded trailer. I figure I added about 600lbs to my normal travel load from last year's trip from Houston to Tampa.
A rear shot from 50' away...
If I git a window to pull the tub and build up the trailer to better match the template, it will be probably near the end of the week after the cold front moves through.
