Old 01-06-2014, 06:38 AM   #40 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Mazda says:
"If we want to dramatically improve fuel economy from here, the only route is through lean burning"
So says Mazda's chief exec for powertrain development, Mitsuo Hitomi.
Though he's talking about HCCI petrol engine development, not a "lean burn mode" in an otherwise standard engine.
Mazda engineers aim to eke the gains by cranking up the engine's compression ratio to 18:1, from a current level of 14:1. Higher compression tends to improve fuel economy because they can achieve the same combustion temperature with a leaner mix of fuel.
HCCI allows for more complete fuel combustion and lower nitrogen oxide emissions.
http://www.autonews.com/article/2014...on-skyactive-2
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Cobb (01-06-2014), Xist (08-21-2017)
