Old 01-06-2014, 06:38 PM   #1193 (permalink)
Arragonis
The PRC.
Originally Posted by NachtRitter View Post
I guess I'm not understanding the problem... The German blog is comparing charts of two different types of models... emissions vs concentration... why is so shocking that one type of model comes out with a 0.9*C difference after ~85 years vs another type of model?
I'm also not clear what you're trying to get at... that policy should be set based on the lowest error bar of the lowest emission or lowest concentration model? That doesn't make any more sense than setting policy on the highest error bar of the highest model (~6.5*C).
Not sure where you get that. They are comparing IPCC forecasts.
As for policy maybe we need to get the above sorted first. Then there is a debate on prevention vs. adaption - assuming there is a problem at all in the first case. At the lower end estimates it us pretty much as before and no real problem.
The IPCC says there is no extreme weather problem, little temp issue and some sea level rise which is unsupported by the evidence.
The world is fine. Protect nature, help others and enjoy your time in it.
The Following User Says Thank You to Arragonis For This Useful Post:
CFECO (01-08-2014)
