Originally Posted by 2000mc
part of why i thought the 9012's might be an issue was the amount of light spilling. with the standard bulb in a non projector lamp, theres a decent bit of spillage over the cut off. but with a 9012 even if perfectly aligned/ positioned in the lamp, what was acceptable spillage is now 50% brighter, and is no longer acceptable.
so if your working with 3x the light, anything above the cutoff is probably crazy bright to oncoming cars, even if the light has the same pattern
HIR is a highbred halogen. Not sure where you are getting 3x the light.
just found this: "These bulbs attain light levels 75% to 110% brighter than stock as a result of an engineering process that deposits multiple, yet almost invisible, layers of semi-reflective coating on the surface of a specially shaped quartz bulb."
