Originally Posted by drrbc
Kittycat left the building- vaya con Dios, muchacha!
You stop shouting down people with your thermodynamics arguments that you neither understand nor use correctly, or you take the bet.
Again, all the risk is mine.
Attitudes aside, the thermodynamic argument is simply not on your side with known chemical reactions and engine conditions. It is incumbent on you to demonstrate how 100 years of engine and fuel designs can be turned on its head simply by adding
just the right amount of extra H2. As I said before, I am making the facile argument, but the historic evidence cannot be ignored.
