Old 01-10-2014, 09:54 PM   #1 (permalink)
zingaro
zingaro's Avatar
z - '13 Honda CRZ
Global - '12 Dodge Ram Cargo Van
zingaro from WNC (western north carolina)
ID:	14398Hello, I stumbled onto this site try to find out what was under the air intake on my Honda crz. It was a resonator?? I just got my scangage II hooked up today and I definetly need some heat in the air intake department. Ive got the front blocked off but am only getting a 20 or 30 d F rise over outside air temp.
Some good stuff here, and hope I can contribute something. In seeing one post about a 130 d F inlet temp im gonna have to fab something. I do have the top radiator hose passing right by the intake scoop.
So ill jump right in to questions:
The fogs .. I don't use um as you gotta have the main lights on + it just suckin juice out of the battery. Should I make a cover for them or try and cover that whole area. I would suspect that honeycomb area around that lite would not b beneficial?
The cover I have is a piece of aluminum flashing painted black and held on partially by the tag and some tie wraps.
Anyhow thanks for letting me in ( it took me 10 minutes to google the answer to the secret question)
Im ready to burn some GAS (less is more) .. z
