Old 01-11-2014, 02:20 AM   #13 (permalink)
Pierrel
Abarth - '10 Fiat 500 Abarth
90 day: 33.4 mpg (US)
Yaris - '03 Toytota Yaris
90 day: 42.13 mpg (US)
Originally Posted by bestclimb View Post
I'm curious what failure mode you ended up with. I am considering requiring a swift/metro in the next few months and have a UG that I would like to use in it.
Basically the UG won't find the protocol and available gauges on startup.
Found this on Suzuki-forums, which is the exact problem I'm having...
The first thing that you need to determine is if your Swift is OBDII compliant - it may not be.
The easiest way to determine this is to check the J1962 connector under the dash and see which of the cavities are populated - if you have only 4,5,9 & 16 it's not OBDII compliant, but uses a proprietary SDL (Suzuki Data Link) protocol."
The Following User Says Thank You to Pierrel For This Useful Post:
bestclimb (01-20-2014)
