Old 01-11-2014, 03:53 PM   #4 (permalink)
zingaro
zingaro's Avatar
z - '13 Honda CRZ
Global - '12 Dodge Ram Cargo Van
Originally Posted by California98Civic View Post
Welcome!
I generally only see 30-40 degrees above ambient temps with a standard type warm air intake, the kind that pulls air from near a hot engine part, such
How much power does the CRZ headlight system draw? Isn't it LED?
Hey: good to know: Im workin on an airbox that draws heat off the top radiator hose + it blocks out cold air from the "grill"
about the headlites.. they are fine. the only way to get the fogs to work is turn on the main headlites. If you could do the fogs without the headlites id be in. but u cant, it does have those really brite drl lites.
u got some good numbers there, man .. .. z
