Old 01-17-2014, 12:37 PM   #180 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by pgfpro View Post
I'm enjoying this thread!!! The one thing I can see is a HHO system could increase the burn rate speed thus help with combustion efficiency.
I have done a lot of N2O testing and have ran systems with out adding additional fuel. I have total control over ignition timing and fuel flow through my engine management system.
What I found from my testing is I could run a small amount of N2O at light load on my lean burn engine and retard timing from 38* BTDC to around 6* BTDC at a 25:1+ A/F ratio and improve BSFC. What it did was make my already fast burn head faster. Running a lean burn engine requires more ignition advance and that is not a good thing. The nitrous help with this.
The down side with nitrous oxide at $30.00 lb. for a 10 lb bottle, the cost doesn't out weigh the improve engine efficiency.
How does a faster combustion event lead to an efficiency improvement? How have you measured improved BSFC? This sounds like an opportunity for detonation, which will not improve fuel economy.
I'm not coasting, I'm shifting slowly.
