Old 01-18-2014, 08:00 AM   #188 (permalink)
IamIan
IamIan's Avatar
Originally Posted by HyperMileQC View Post
but remember that when you kill the engine with the FAS system, you can't bump start to restart the engine.
Only in Phase-I of FAS while it is actively cutting the fuel injectors.
In Phase-II all FAS is doing is holding the clutch signal to make the car think you still have the clutch pressed down ( even if you do not ).
I have FAS and I have bump started ... when I FASed down a hill ... and I've also used MIMA to use the IMA to restart ... If I hold in my FAS button I stay in Phase-I which means I can also use MIMA to drive the IMA --- effectively a MIMA-EV-Mode... once FAS is in Phase-II the engine will restart from the RPMs.
What I would like to work around is a way to activate or deactivate the DC-DC converter functions with a switch. That way I could preserve my 144v juice and I could charge the IMA battery less often. On short trips, I could let the DC-DC functions off all the way and charge my 12v battery at home with my 2A charger.
Sounds like you need the DC-DC keep alive... usually combined with FAS.
When the IMA Battery Voltage is present ... any time after the high voltage connector activates in the beginning ... The DC-DC default condition is on in alternator like mode ... the OEM system sends the DC-DC a signal to turn it off ... if you break that signal wire with a relay you fall back to the default condition of DC-DC being on.
Although the DC-DC enable doesn't have to be integrated with FAS as one unit ... that is a commonly used method.
If you haven't seen it yet ... A good write up on the step by step of doing FAS with the DC-DC enable is the one Highwatter did Link
The Following User Says Thank You to IamIan For This Useful Post:
HyperMileQC (01-22-2014)
