Old 01-18-2014, 09:58 PM   #35 (permalink)
oil pan 4
I'm sure you have made a post on your LiFePo4 batteries, and I'm sure I've read it... what batteries did you go with, and how many? Do you use a BMS?
I'm considering LiFePo4 on my motorcycle where weight can really make a difference.
2 of the batteries are made with CR26250 cells. The original battery, the small one uses 20 cells, the second larger battery uses 28 cells.
Then the super battery uses eight AMP20 cells.
No BMS.
Here is the latest update to my LiFePO4 battery project:
DIY: BYOB, for more power, a lot less weight - Page 7 - Diesel Place : Chevrolet and GMC Diesel Truck Forums
redpoint5 (01-19-2014)
