Originally Posted by darcane
Yes, that's fine and no it won't cause any problems. I do it all the time.
Note, you may need to hold the switch down (takes about 1-3 seconds for my car, depending on RPM) before the engine stops completely. If you stop interrupting the circuit before then, it will fire back up.
So far the only "trouble" I've had with my switch is that I tried to bump start it once and forgot to flip the switch back. It threw a code for a faulty crank sensor since the kill switch also kills that circuit. I forgot several times, only got the code once. I cleared the code and it's been fine ever since.
Forgetting to flip the switch back is exactly why I want to use a momentary switch...
