Old 01-21-2014, 08:43 PM   #37 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by boostmaster View Post
What should a VX trans cost?
Wife and I swapped some worn bearings and the clutch this past summer so we can pull the trans within 30 minutes or so!
My 1992-1995 CX transmission, which has the exact same gearing as the VX, was "A" grade quality $300 out the door (93K miles on it). And I'm impressed and jealous that your wife can work with you, will work with you, and is so skilled you two can do the swap in 30 minutes. Grrr....
