Old 01-23-2014, 02:53 PM   #1 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Swapping Trans in the Motor-Rolla
I see all of the Civic threads about swapping parts, including transmissions and I want to look into something similar for my Corolla.
I *think* I have the A245E transmission and I have found the A246E, which I believe is swappable (need to confirm that too). According to Wikipedia, these are the gear ratios for each:
I've been using this Gear Ratio Calculator, but I'm not really good with gearing and what it all means, so can someone help me decipher the data? What I'm looking for is a peppy car in the first couple of gears and the best possible cruising gear (in terms of lowest RPM).
Can someone tell me what I need for what I want? Shorter 1st, 2nd and 3rd and taller 4th with a tall final drive? Or the exact opposite? If each gear in each trans was easily swappable, which gears would you choose?
Ahhh... I'm so confused!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
