Old 01-26-2014, 04:37 PM   #189 (permalink)
HyperMileQC
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
The "Phases" you are talking about is the switch held on (Phase-I) and the switch relased after engine cutoff (Phase-II) ? If this kill the engine like when you key EOC, then you could really bump start like I do. Not with the electric motor.
About the DC-DC...
If the signal is normal the DC-DC converter default condition is alternator like mode. Then if you cut that signal with a switch. The DC-DC converter will stop working in alternator like mode until you return to OEM signal, right?
Then what doesn't work? What I was thinking about is a way to decide if the DC-DC converter works in whatever condition it wants or is OFF. I was not talking about the DC-DC enable thing. Why would I want to charge my 12v battery even during OEC when what I want to do is make the DC-DC converter work less often. You could compare this idea to an "alternator ON/OFF switch" on conventional cars.
90% of my mileage is short trips. So I could let the DC-DC converter off all the way and charge my 12v battery at home without problem. I want to save the 144v juice for assist and also to charge less often.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
