Old 01-26-2014, 09:09 PM   #11 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
I've pretty much abandoned the idea of a full tranny swap. What I'm considering is swapping just the first two gears for shorter ones. I want to get into the third and fourth gear ASAP and (correct me if I'm wrong), shorter first and second gear will get me up to speed faster, making the ECU switch gears sooner. Am I wrong in that thinking? If so, than this whole idea is definitely nailed inside a coffin.
As an aside, just for the first and second gears, what puts more torque to the wheels, shorter or taller gears?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
