Old 01-28-2014, 12:53 AM   #192 (permalink)
HyperMileQC
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Thanks for your clarifications on the Insight electricals .
I'll try to do a FAS but i'll probably won't do DC-DC enable. If you want to bump start after FAS you have to hold the switch so it stay in Phase-I, right? Then you release the switch when the engine starts I guess.
I already have a dumb grid charger for the 144v battery but I don't charge in the winter. This is one of my favorite mod.
On the DC-DC switch, what would I have to do to put off my DC-DC converter when I drive? Would it even be possible? If not, I'll probably stop thinking about this modification.
I already did some modifications to reduce my electricity consumption like EPS disable, LED position lights, tail lights, map lights and immatriculation light. I also disabled the DRLs. I will soon replace all my cluster lights with LED. I try to turn off the radio some times...
Also when you do P&EOC your electricity consumption is reduced because more than 50% of the time your engine is off.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
