The consensus around here is that the way you accelerate has little bearing on your economy. I tested different acceleration methods with my Toyota Matrix here:
http://ecomodder.com/forum/showthrea...rix-27152.html
What really matters is the way you slow down. Drive as if your brakes don't work. I repeat: avoid using your brakes (and engine braking, for that matter) at all cost.
