Old 01-28-2014, 07:31 PM   #28 (permalink)
aerohead
Kammback
I'm inclined to say yes,but I'm gonna put up some images for you to look at.
Your LE was probably optimized by Toyota and may already be at it's sweet-spot for backlight angle,trunk height,trunk length,and C-pillar design.
With the Dodge Daytona,you'll see that as the void under the 'Template' is filled in,the drag shows a downward trend generally.
With the VW Golf,you also see that the drag is lowest when the roofline is closest to the 'Template.'
Finally,you can see how the Mercedes-Benz,already near the 'Template',reaches lower drag as more and more length (boat-tailing) is added.
Kamm use a profile very close to the '
Template' and a comparison of the Camry to it might give you some ideas.
Here's the tables:
