Originally Posted by Baltothewolf
On the other note, I have no idea how to tell the difference between rads, this young blood is still learning.
That is pretty simple to determine.
If the tanks are top and bottom, with the radiator cap somewhere in the middle then its likely a vertical rad.
If the tanks are left and right, with the cap at on end, then it is a cross flow design.
I just googled it and it looks like your Camry has a vertical flow radiator.
Time to get that rad flushed and the coolant replaced with Evans or Engine Ice.
