Originally Posted by redpoint5
I'm not going to discourage you from doing maintenance on your car, but coolant is usually good for 10+ years. In fact, I've never replaced coolant before and have never had an issue with the cooling system.
That said, I'll be flushing the original fluid from my 2001 CBR600 this year.
10 years, I remember when it was recommended that you change it every year.
That said, when you got to replace the coolant in your cbr, if your not going to use Engine Ice or Evans, make sure you use the honda coolant and distilled water when you refill it.
