Originally Posted by poomanchu
Or the OP can just use what is being shown, without resorting to using house siding that flaps in the wind as it is already cut and mounted? I don't know, I always thought clear is a bit more invisible than an opaque coating
If you fasten it properly, sheet aluminum won't "flap in the wind" any more than any other material might. Considering that a radiator is basically black, and that most grilles are either chrome or black, you won't notice a grille block that is black.
