Old 02-01-2014, 11:06 PM   #54 (permalink)
GeorgeWiseman
Blue Aveo - '08 Chevrolet Aveo 5
90 day: 25.13 mpg (US)
Heating the fuel
Originally Posted by Old Mechanic View Post
In general I agree with your points George, but if you consider the next generation of fuel injection then give this link a look.
Transonic Combustion | Revolutionizing Combustion Technology
Mech
I've done some experimenting with pressurizing gasoline and heating it (see my book 'Extreme Mileage, 101').
I'm also familiar with the thermodynamics of supercritical fluids.
I perused your website and would have questions, based on my own research. Questions like:
1. How do you achieve 4000 psi with an ordinary EFI fuel pump?
2. How do you control the temperature in the exhaust heating unit to maintain 600°F?
3. Have you tried heating the fuel past 900°F? My experiments got 'interesting' in that range.
4. Have you run into issues of maintaing exhaust temperatures when idling?
5. What are you using to control the air:fuel ratio? I've found that controling the fuel ratio of heated fuel can be tricky, because gasoline is a mixture of over 4000 constituents that vary in percentage, each with its own vaporizing and thermodynamic characteristics.
