Old 02-02-2014, 05:53 PM   #27 (permalink)
tvbd56
0.29 Cd and decreasing
Red Rocket - '90 honda CRX HF
Team "Old SKOOL"
90 day: 53.46 mpg (US)
Originally Posted by California98Civic View Post
Thanks for these photos. I have a thought for you to consider. It is possible that these two outer edges are too far out, too close to the outer edge of the tire. When I did mine I saw research for the Prius, second gen I think, that suggested that the outer edge of the spats should be an inch or two inside the outer edge of the tires. It's about how far the airflow gets pushed to the side. You want it to go just far enough to clear the front of the wheel and not so far as to extend the effectual frontal area of the car (via blown out airflow, apparently).
Thanks again,
james
Alright I'll try that, I'll cut two inches off of each spat. I have seen ones that are like that before. I'm hoping that there are actually doing something
