Originally Posted by Old Tele man
...sorta *implies* the use / insertion of either: (a) metering plate/orifice or (b) adjustable value to control/limit coolant flow at engine idle, but not at full load conditions.
Coolant flow at idle is generally marginal, so if you have a pump with suficient linear flow, why would you want to restrict coolant flow? The Thermostat controls the cooling and is the metering orifice limiting flow to the radiator.
