Old 02-03-2014, 08:01 PM   #6 (permalink)
PAFirefighter11
Diesel FTW
PAFirefighter11's Avatar
Golf TDI - '03 Volskwagen Golf TDI GL
90 day: 44.63 mpg (US)
Originally Posted by TurnpikeCruiser View Post
PAFirefighter had done the duct tape grille block. I believe the coilovers and lower lip were from the owner previous to him.
Great meeting you, Scott. Enjoy it!
Yep, the coil overs had been done by the prior owner. Rides a bit rough but helps keep that FE up. The grille block was just duct tape to test for any FE improvements. I did see some, so the next step was going to be either fiberglass or lexan blocks. The tape actually didn't bother me too much, though, since it matches the car fairly well and worked!
Definitely keep updating here. I'm looking forward to seeing you get better FE than I did. You downloaded the fuel app, right? The last fill mileage was at 155,993 for your records btw.
-Rick R
-'03 Volkswagen Golf TDI (49.9 MPG - Stock with Eco Friendly Tires
-'98 Jeep Grand Cherokee 5.9L - 32" MTZ's, 4.5" lift (11.5 MPG)
-'98 Pontiac Firebird Trans Am WS7 5.7L (22 MPG)
-'01 Pontiac Firebird Trans Am WS6 5.7L (22 MPG)
