It is not just an engine swap. You'd need to swap the whole gearbox, electronics and hybrid system too.
The Toyota HSD gearbox is totally different from the Insights CVT - if you have that on hand, because the 5 speed MT was more popular (and economical).
The Insight is not the largest of cars around, it might not fit.
The Insight has a low carrying capacity, so if you increase the weight you need to upgrade the suspension as well.
If I had a Gen1 Insight I'd like to install a small PHEV booster pack.
I've got a Gen2 Insight and I sure want a small PHEV booster pack in that
