Originally Posted by elhigh
Not a tractor axle. Gearing is lower - numerically higher. Example: Farmall Cub, 46 ring, 10 pinion teeth for 4.6:1. Some tractors with planetary or portal axles may have a higher ratio in the final drive.
Thanks for clarifying. I was trying to think outside the box...
