Old 02-06-2014, 10:32 PM   #120 (permalink)
GeorgeWiseman
Blue Aveo - '08 Chevrolet Aveo 5
90 day: 25.13 mpg (US)
Originally Posted by sarguy01 View Post
I want to address your math. I see you used displacement, rpm and volumetric efficiency to calculate air flow, but that math assumes the engine was at wide open throttle, correct??? You were not at wide open throttle and therefore the throttle plate was restricting air flow into the engine. Isn't your lie just an oversight on your math? Please explain since I obviously don't understand.
No, the 'lie' math has absolutely nothing to do with wide open throttle. The math is for normal driving with normal throttle use. The math simply takes the weight of air that ACTUALLY goes through the engine and compares it to the weight of fuel that ACTUALLY goes through the engine during NORMAL vehicle operation.
You can confirm this by using your own scan gauge on your own vehicle just like I show you. I never mention anything about wide open throttle.
Can you tell me why you think I'm talking about wide open throttle?
