I don't want to put a downer on this but Torque is not exactly accurate out of the box. I have been using it for a while and to calibrate it isn't very straight forward. I use Fuelly etc to record actual mileage compared to fuel used, then compare this to what Torque has worked out then trim from there in the 'Settings' menu. Unless you have already done this I would take your results with quite a huge pinch of salt, out of the box Torque was under reading by 25% for me. Reading on the internet large variances are not uncommon in this app.
