UG Potential Available Gauges
I don't think the PDF makes an accurate comparison. Download the manuals for both and do your own. See two examples below.
Table 1 - Potential Available Gauges
% Engine Load
Engine Coolant Temperature (oF)
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
Short Term Fuel Trim Bank 2
Long Term Fuel Trim Bank 2
Fuel Pressure (PSI)
Intake Manifold Absolute Pressure (PSI)
RPM
MPH
Timing Advance
Intake Air Temperature (oF)
Mass Air Flow Sensor 1 (g/s)
Absolute Throttle Position 1 %
Bank 1 0xygen Sensor 1 Voltage
Bank 1 0xygen Sensor 2 Voltage
Bank 1 0xygen Sensor 3 Voltage
Bank 1 0xygen Sensor 4 Voltage
Bank 2 0xygen Sensor 1 Voltage
Bank 2 0xygen Sensor 2 Voltage
Bank 2 0xygen Sensor 3 Voltage
Bank 2 0xygen Sensor 4 Voltage
Run time since last Start (hours:mins)
Distance traveled with Check Engine Light On.
Fuel Pressure (Diesel)
Bank 1 Wide 0xygen Sensor 1 Lambda
Bank 1 Wide 0xygen Sensor 2 Lambda
Bank 1 Wide 0xygen Sensor 3 Lambda
Bank 1 Wide 0xygen Sensor 4 Lambda
Bank 2 Wide 0xygen Sensor 1 Lambda
Bank 2 Wide 0xygen Sensor 2 Lambda
Bank 2 Wide 0xygen Sensor 3 Lambda
Bank 2 Wide 0xygen Sensor 4 Lambda
EGR Flow %
EGR Flow % Error
Evaporative Purge %
Fuel Level % of full
Number of Warm-ups since Check Engine Light Cleared
Distance traveled since Check Engine Light Cleared
Evaporative System (PSI)
Barometric Pressure – Inches of Mercury (inHg)
Catalytic Converter Bank 1 Sensor 1 Temperature (oF)
Catalytic Converter Bank 2 Sensor 1 Temperature (oF)
Catalytic Converter Bank 1 Sensor 2 Temperature (oF)
Catalytic Converter Bank 2 Sensor 2 Temperature (oF)
Battery Voltage
Relative Throttle Position %
Outside Ambient Air Temperature (oF)
Absolute Throttle Position 2 %
Accelerator Pedal Position 1 %
Accelerator Pedal Position 2 %
Command Throttle Position %
Engine Oil Temperature (oF)
Mass Air Flow Sensor 2 – Calculated
Instantaneous MPG
Average MPG – General
Average MPH – General
Average G/H - General
Run Time – General
Distance – General (miles)
Fuel Used – General (Gallons)
Instantaneous Gallons/Hour
Fuel Level (in gallons or fuel to empty)
Distance to Empty(DTE) (miles)
Time to Empty(TTE) (Hours:Mins)
Volumetric Efficiency (MAP vehicles only)
Average MPH – Trip
Average MPG – Tripl
Fuel Used – Trip (Gallons)
Average Gallons/Hour – trip
Run Time – Trip (Hours:Minutes)
Distance -Trip (miles)
Oil Change Distance (miles)
Service Distance (miles)
UltraGauge Internal Temperature (oF)
