Like others have said, reducing accessories reduces the magnetic field and thus resistance within the alternator, raising FE. My friend had a HUGE (like 2000W) stereo in his car; when he turned his amp on, it was like a "slowness switch".
FYI - a car's electrical system (necessary stuff like ecm, ignition, sensors) is typically somewhere around 300-400W without lights, radio, etc. Newer cars are more than older cars I'm sure.
Noone's mentioned using a deep cycle battery and a plug-in charger. This is what I'm planning on doing; running a kill switch on my car and when I'm commuting 15 miles to and from work, running on straight battery when I can. The alternator sees no extra duty and the deep-cycle battery is made to be discharged and recharged with minimal sulfation. Electrical power is more efficiently produced in a power plant than in your car, and with current prices, it's way cheaper too!
