Old 02-08-2014, 05:01 PM   #17 (permalink)
aerohead
temp and efficiency
Originally Posted by Lazarus View Post
The hotter the engine the more effecient. I'm currently running water temps of 200-207. If I bumped that up to 215-220 and ran a high quaility coolant. What kind of bump in FE do you think? At what temp would the head gasket become a concern.
The only relationship that I know of,is raising the temp in the combustion process with high-temp metalurgy or ceramics such that the delta-T is actually increased and waste heat eliminated.An adiabatic cycle.No cooling system.
Experimental engines have been tested.Nitrogen oxides were an issue at temps where 'inert' gases begin to react.
Vapor-phase or dry lubrication is also of interest.
Be careful.
