Thread: Wai
Old 07-04-2008, 01:37 PM   #5 (permalink)
gascort
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
The K&N is an interesting thing. It allows more air in when it's new, but doesn't filter as well. When it gets dirty, it restricts air a bit, but filters much better. I don't mind them tremendously as a cost-saving measure over the lifetime of a car, but they definitely aren't as good as a WIX paper filter.
Oh, and if you use the K&N, you will have to periodically (once a year or so) clean off your Mass Air Flow Sensor (MAF or MAS depending on who you talk to) with special cleaner - not carb cleaner or alcohol - that you can pick up at an auto parts store.
The electrodes in the sensor get oil on them from the fresh K&N, then they gradually accumulate dirt on them as it gets through the filter and sticks. Since they're heated resistors that are supposed to react to real-time temperature change to read how fast air is moving into your engine, they need to be CLEAN.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
