Old 02-10-2014, 04:15 PM   #7 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
You shouldn't have to pull the dash off to do it. It will help if you have a friend assist. If one of you pushes the wire/hanger into one of the grommets and one of you grabs a flashlights and pokes their head under the steering wheel/footwell to look for the wire coming through, then pull it through as much as you need, it should be pretty easy without tearing anything apart.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
