The wire came with the temp. gauge I bought, but it's not going to be difficult to find ones similar. You can go to a donation store and get some old headphones for cheap and then chop off the ends.
But before you go installing wires unnecessarily, you will want to figure out how many connections you need to make onto the Arduino board. At that point you can figure out how many/what kind of wire you'll want to use. Depending on how many connections you need to make, you might decide to use something like telephone wire (4 wires) or CAT5 cable (8 wires). It also depends on where the sensors you need are located within the engine bay.
So figure out how many connections you need and then find where all the components are that you need to access. It will save you a lot of trouble in the long run.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
