Old 02-13-2014, 10:30 AM   #6 (permalink)
poomanchu
Civic Type-DX - '97 Honda Civic DX
90 day: 40.3 mpg (US)
Originally Posted by Boosted24 View Post
Thanks poomanchu, the front end swap was easy i do all my own work.
Ill look into the torque app and the obd2 reader, sounds simple and inexpensive, what all does it do?
My transmission has a grind in third and i want to get a different one before i take this one out. Also my throw out bearing needs replaced too is a little noisy.
Nice job looks great!
Torque is an OBD2 reader, much like scan or ultra gauge. I get an annoying evap check engine light and this clears it no problem. Too lazy to get the purge valve You can customize your gauges and layouts and what it reads, pretty neat.
https://play.google.com/store/apps/d...l.torque&hl=en
In the meantime GM syncromesh (available as Penzoil syncromesh) cured my 2-3 grind in my gsr trans (thats all I run in any Honda still have 2 quarts of MTF i need to give away). I'm a believer of it lol. That TB though...
Good luck!
The Following User Says Thank You to poomanchu For This Useful Post:
Boosted24 (02-13-2014)
