Old 02-21-2014, 08:58 AM   #6 (permalink)
backpacker3
backpacker3's Avatar
Homer - '02 Pontiac Sunfire SE
Team Pontiac
90 day: 30.05 mpg (US)
Originally Posted by niky View Post
But the gains from this aren't huge. A little bit here and there. To create a tune for maximum economy means running things very lean in areas, which leaves less margin for error when you get a batch of bad gas or if the weather gets too hot. It takes a lot of development, and I don't know if there's enough of a customer base for this to be commercialized. (I mean, a lot of people might want it, but how many are willing to pay? And you'd have to develop a "safe" map for each model you support...)
Some newer cars already come with such maps for their "Eco modes", and they include dialled back timing, dulled throttle response and altered transmission algorithms.
That's the advantage of a flash tuner though you can still switch between a number of different tunes including a stock tune. You could even use a custom flash tuner in place of a scangauge or ultragauge. I wouldn't necessarily try to sell this I really would like to try to makes this something you can build yourself like the MPGuino. Also I get that even for those who have a manual transmission this isn't as helpful either but for someone with a automatic adjusting those parameters can improve gas mileage quite a bit.
This would be pretty similar to the "Eco modes" in new cars if you look at my original post I talked about that. I was just wondering if anyone has experimented with tuning a car for gas mileage only.
