2003 hybrid battery help
I just finished replacing the sticks in my 03 hybrid and the light will not clear, I have a generic scan tool but it does honda manufactures control modules, and I am throwing a temp sensor #3 low voltage, is one of the 3 sets of wires that run along sticks? or that an actual PTC built into the sticks? When I removed the sticks the 3 sets of wires came off one actually came apart I ended up adding new solder to it and tucking it back in but are these built into the PTC? Do I need the cut and tuck them back into the case? Any ideas? If no one I will prolly just figure out how to run just the gas motor but I will have to look through the forums.
thank you
Eric
